Edit
IDEs and programming languages for Developing Smath Plugins
To develop plugins for Smath Studio you can use an integrated development environment (IDE), which is just a fancy term for a software application that helps you create applications that may be used by Smath. The IDE may be used to create plugins in the particular programming language of your choice. However, the programming language you use must be able to utilize the Microsoft .NET Framework.
There are several possible choices that may be used for developing plugins for Smath Studio. (Note: Theoretically, the IDEs and languages mentioned here should all work, but they have not all been tested with Smath. Also, this list is not exhaustive and may be expanded.)
Edit
Programming Languages that may be used to develop plugins for Smath
C# | Website
Visual Basic | Website
F# | Website
IronPython | Website
IronRuby | Website
Edit
IDEs that may be used for developing plugins for Smath
Visual Studio Professional Editions | Website
Visual Studio Express Editions | Website
SharpDevelop | Website
Wing IDE | Website
